Tips on racing with slicks?
- cjthor
Going to the track tonite with slicks for the first time. Alllways ran just street tires and avoided the water box like the plague. I hear you want to start your car in second in the burnout box? So Im guessing you roll your front tires in and rip the Ebrake right? Man for alll my driving experience Ive never done this crap! Help?
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
- therieldeal
Re: Tips on racing with slicks?
i'm on drag radials but the same ideas apply... here's how i do a burnout:
roll into the water, set the handbrake
give the tires a quick, short spin. you only need them to turn around once, you are just trying to get the whole tire wet.
pull up a couple feet, just out of the water, set the handbrake again.
rev the motor up a bit... 3-4k. let the clutch out slow till it starts to bog down the motor, then drop the clutch and floor it. eventually you'll drag the back end foreward... or if you dont, let the handbrake down and keep spinning until you are well away from the water. please dont go past the staging line though, lol.
i have always done my burnouts in 1st, but you can experiment and see what works best for you. the most important part is letting the clutch out slow until it starts to grab. if you just rev it up and dump it, you WILL break an axle.
yeah dont past the starting line most tracks Greatlakesdragway by me if you pass it theyll just tell you to take the pit road back inline.
Excellant advice. I'll use it in the spring when I go to the track.
Yeah it important to let the clutch out slow I broke a axle once lol.
grabyskyh, your a moron.
