KLZE Turbo Dyno Sheet 299whp
I made 299whp and 244 ft lb Torque @6500rpm on a Stock ZE Turbo at 5.5psi without a tune. Megasquirt is on the way!! Let me know what you guys think. 7psi dyno run coming soon.
Re: KLZE Turbo Dyno Sheet
i cant see it!!! i mean i see the image i just cant see anything on the image lol
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
Re: KLZE Turbo Dyno Sheet 299whp
Does anyone else have any ZE Turbo Dyno sheets or numbers I can compare to?
VIDEOS PLEASE!
-hec
- XxantwawnxX
I never dynoed mine.....: (
Ill post up some vids on youtube soon as I have someone take some for me or If I can rig up something to hold the camera in the car.
- Mazdaspeed96743
Whoa this car must yank
I never dynoed mine but FAK this makes me want to slap my turbo right on again
-hec
- marcdh
Excellent work! Long may it last, and good luck with the megasquirt.
View Worklog
View Worklog
what do i need to do ... in order to make a KLZE stand ... 14.5 psi without breaking up ?
K8 :: 136.8 bhp---160 nm---108.0 whp---118lbs/torque
ET: 15.567 @ 136 kmh (84 mph)
"Racing a Honda is like being in the special Olympics, you may win, but in the end your still retarded."
