My reverse lights are not functioning. I have replaced the swtich on the transmission and they are still not working (the wire had detached from the old switch after swapping the transmission). All other lights in the taillights are working. I even swapped in a completely different harness to test if that was the problem. Even with another harness and a stock bulb it still didn't work. I've even tried swapping the LED light I had wired in as my reverse light. No luck there either.
Is there a fuse in the engine bay for the reverse lights? Or one inside the car?
Reverse lights
Reverse lights
Friendship is like pissing your pants: Everyone can see it, but only you can feel its true warmth.
- Ryan
Re: Reverse lights
Bulbs are burnt out?
Re: Reverse lights
Ryan wrote:Bulbs are burnt out?
Nope, I'm not using any kind of bulb and I made sure that when I swapped the harness the bulb I used was in working order.
Re: Reverse lights
something similar happened to my car when i bought it the diff was it was my runing lights not working, what i did i checked the fuses in the fuse box on the driver side and that fixed it
Re: Reverse lights
That's prob it. I will check the next time its nice out. Any idea which fuse is for the reverse lights?
