Ok, I have a 94 Mx-3 4 cyl DOHC. I have never actually driven this car so I am not sure what all works, but it does have cruise, ac, sunroof, power windows and doors. I am not sure if any of that works.
Currently I am rebuilding the engine and while thinking about cleaning the bay I stumbled upon these wires. They are cut and I have traced them to go near the steering wheel. I guess they are going to the CPU?
Does anybody know about these?
If I remember correctly the wires are red, purple, green, yellow
Thanks
Mystery Wires?
Re: Mystery Wires?
Doesn't look stock if you ask me.. Have you tried looking from the inside under the dash to see where they go?
Worklog! - updated Jun/26
Re: Mystery Wires?
no, I don't think it is stock, but whoever did it did a pretty good job. The wires go near the clutch pedal, I guess to the CPU (not ecu). Kind of hard to tell where they are going, I think they split off in 2 directions. I crawled up under there and looked. I guess I need to pop off the panel and get a better look.
What can you guys think of? Why would there be extra wires into the engine bay that hook up to the cpu?
Re: Mystery Wires?
Just cause it goes to the joint box under the dash, don't assume they go to the CPU - I just added into a harness under there the other day to get a constant source of power, and it had nothing to do with the CPU itself. If you really want to know, you could look up which pins they are attached to in the shop manual.
Re: Mystery Wires?
Well, after doing a little searching I figured it out. Looks like it is the cruise control. Some wires go to the brake and the others go to the switch on the wheel. I'm guessing this is an aftermarket cruise control and when someone sold the car they had it taken out? Bummer, I'll have to figure out how to get it working again, but first I need an engine. Still waiting on my engine rebuild kit to come in the mail *sigh*
