If anyone remembers, I have Gro Harlem's ZE MX-3. It worked great for a couple months, now it's got me completely stumped.
The car is idling fine and is drivable... however, there seem to be "dead spots" in the throttle. These spots vary, but are most noticable on common highway speeds.
For example, if I'm going 75 stable, the car will completely lose throttle down to 70, then "buck" back up to 75 and continue this vicious cycle.
I can, however, while going 75, give it some juice, in which it hesitates for a split second, buck, then kick back with it's ol' ZE fury. Let's say the ride isn't very pleasant. Especially with completely shot engine mounts and balljoints, a bad cv axle, and control arm bushings.
For the record, the car's got replaced:
Rebuilt Injectors
FPR
Timing belt/tensioner
O2 sensors
vacuum hoses
Spark plugs/wires
HEI mod and blaster 2 coil
Replaced disty cap and rotor
replaced ignition module
Grounds checked/cleaned
TPS
Fuel Filter
And believe me, it's GOT fuel pressure!
![Image](http://i5.photobucket.com/albums/y169/SuperK86/My%20Car/CRW_6064.jpg)
FUEL PRESSURE!!!
So in accordance to "SuperK's Guide to Fixing Cars Like Certified Mechanics Do", I am continuing my journey of randomly replacing items that could be wrong and wondering if it'll fix it for at least long enough for the driver to get halfway home.
I did find this topic, which was particularly interesting to me:
http://www.mx-3.com/phpBB3/viewtopic.ph ... af#p380535" onclick="window.open(this.href);return false;
So I thought, hey! How about checking my VAF?
... And I read that thread... and realized SuperK is after all, partially retarded, partially awesome (which levels SuperK out to be quite average)
And I couldn't figure out exactly what I'm doing... or how to do it right. I have a digital voltmeter, and a set of screwdrivers, sockets and hands.
Can anyone walk me through testing my VAF? I pulled it off today while replacing the filter and noticed it... jingles? If anyone cares, I can remove it and record "jingle bells" by shaking it in front of a microphone, if that will entertain you. I... don't think that would cause an issue...
