I need to replace my rear wheel hub/bearing assy. 1992 gs, no abs. Now what I need to know is does the rear hub need to be pressed in? looking at the pictures of replacements I dont see how else it can go in.... can this be a diy job?
please help!
-Chris
rear wheel hub replacement
- GreenMachine
'92 GS-no lip. Klze. no cat. phenolic spacers. no power steering. no a/c. hei mod. poly filled mounts. probinator chip. loud exhaust. b&m shifter. tokico struts. suspension tech springs. axxis 17 in rims.
'86 mr2-stock and still hauls a-- in curves.
'05 Gsxr-50 tooth stunt bike
![Image](http://myspace-459.vo.llnwd.net/01142/95/48/1142528459_l.jpg)
- marcdh
Re: rear wheel hub replacement
I thought the point was the bearing comes pressed into the complete assembly that you buy? Never done it though, so I wouldn't know for sure ![Confused :?](./images/smilies/icon_confused.gif)
View Worklog
![Image](http://marcharrington.co.uk/banner2013.png)
View Worklog
- 2fazed
Just replace the rear spindle. I know your taking a chance on another used bearing. But if you need a quick fix, there you go.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
doesnt matter if its abs or non abs. same as front axles.
-hec
