CryO2
94drumx3
CryO2
Post by 94drumx3 »
I did a search on this and there was pretty much just one topic on it that ended in a few posts. and it was 5 years ago...so since then has anyone tried this stuff?
Benefits?
Disadvantages?
http://www.designengineering.com/produc ... m=sc&cid=1
Never be afraid to try...amateurs built the ark, professionals built the titanic.
XxantwawnxX
Re: CryO2
Post by XxantwawnxX »
Spraying Co2 on your intercooler is gonna make it cold as crap...no doubt about that. In turn i think your intake charge will drop ...sooo more power..and good for preventing pre ignition.
Return to “Forced Induction”
