Klze runnig rich at idle?
hgallegos915
Post by hgallegos915 »
Oks.. my ze had bad intake manifold gaskets.. corrected it.. now the afs are weird..
its normal under cruising.. normal under WOT...
but AT IDLE its rich.. like at 10.1 and it makes the car stall.. so i played with the afs, i made my fuel pressure at 25 and it kinda helped.. 12 afs.. but at idle? o.0
new spark plugs, (from the faqs) cables are good(a few months old)
I have a kl36 ecu.. cant check codes as i lost the cover that tells you which one is the FEN pin.
I have been adviced it can be the fuel filter?
NOW i do have a WALBRO 255.. will that make my car run rich at idle?
-hec
Re: Klze runnig rich at idle?
Did you find a cap for your Diag box? If not I can take a pic of the inside cover on mine and send it to you.
irocthaDOHC
Post by irocthaDOHC »
Do you have curved neck ze? maybe probinator chipped ecu would be better.
How old are your O2 sensors?
hgallegos915 wrote:NOW i do have a WALBRO 255.. will that make my car run rich at idle?
I would think unless you had an AFPR then yes it would make it run richer since you are pushing more fuel but I am not for sure...
Custommx3
Site Administrator
Post by Custommx3 »
You need an AFPR with a 255 Walbro, or you will run rich. Id suggesst an Aeromotive AFPR
You don't need one unless you have the 255 High Pressure version ;)
hgallegos915
I already fixed the problem, i do have a walbro 255 version.
Using a cosmo afpr.
15 psi lol
anything higher will make me run rich.
-hec
