92 mazda MX3 wont start!! Electrical prob!!
Posted: May 25th, 2008, 1:05 am
So I posted earlier about distributor problems. That got solved and it ran great untill yesterday....
1992 MX3
1.6 4cyl SOHC
Manual Transmission
I was backing into a spot, and it died. Thought maybe it stalled cuz I was being stupid or something.... tried to re-start... DIDNT WORK. Tried a couple more times, figured I would compression start it. THAT didnt work. So after 250 dollar tow, it's at home now where I can mess with it more. So the battery is new, holds a 12v charge, 10v when you try and start it. So the battery is good. Took my plug out of the number 1 cylinder, plugged it into the wire and tried to start it so I could see if it was sparking or not. NO spark....
Plugs, wires, cap, rotor, distributor, ignition coil are all new. So its between the coil and the battery(obviously). Any suggestions??
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
1992 MX3
1.6 4cyl SOHC
Manual Transmission
![Welder :welder:](./images/smilies/welder.gif)
