Hissing sound right around fuel regulator
I'm getting a fairly loud hissing sound at idle on my KLZE coming from right around where the fuel rails start (basically near the regulator). Is this normal, or a vacuum leak on the IM?
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
Re: Hissing sound right around fuel regulator
if its idling ok, its normal, if its not, vac leak.
-hec
Check for Vacuum leaks, I had a similar sound and I thought the same thing wouldnt idle right if there was a vacuum leak and it took me 2 days of looking to actually figure out i had a whole line that wasnt connected.
Well, where it's hissing I can't see anything disconnected. :/ I wonder if the intake is leaking at the gasket.mazdanut08 wrote:Check for Vacuum leaks, I had a similar sound and I thought the same thing wouldnt idle right if there was a vacuum leak and it took me 2 days of looking to actually figure out i had a whole line that wasnt connected.
It seems to idle OK, but somewhat rough. Could that be normal for a fidanza flywheel?
- Gord
take some carb and choke or brake cleaner, slowly spray in different spots in the engine bay, if your rpms rise well then you know there is a leak, if it idles slightly rough then you have a vacuum leak more or less
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
Wow.. good idea. I'll try it tonight.Mnemonic wrote:take some carb and choke or brake cleaner, slowly spray in different spots in the engine bay, if your rpms rise well then you know there is a leak, if it idles slightly rough then you have a vacuum leak more or less
- Gord
