CHECK ENGINE LIGHT
Posted: May 19th, 2008, 7:49 pm
Hey im not sure if this is the right place to post this, but here it goes.
A couple days back i put my car up on a lift and wanted to shampoo my oil pan area because i just got the car and wasnt sure if its a oil leak or just old oil that wasnt cleaned up. so after i put some shampoo on i used a high pressure gun to rinse all that off, after that i took the car down and got on my way and the car started to miss fire i think, and my check engine light came on..... i dont know much about these engines but i think i wet my coil springs....... if i did will this miss firing go away and will the check engine light go away as well if it dries?
