transmission mounting bolt/nut
Some of the nuts that are welded to the frame (for the transmission-mount-bolts) have stripped and atleast one nut has completely detached from its welding points and is spinning freely. Is there a way to get to those nuts without cutting any body panels? like from the wheel well?
![Image](http://img517.imageshack.us/img517/5927/fliegetn0ss7.gif)
- marcdh
Re: transmission mounting bolt/nut
Eugh one of mine broke in half for the engine mount x member, still welded in! Took me 45 mins to carefully dremel off the 3 tack welds! Sounds like you got a worse deal
Can you not just remove the wing?
View Worklog
![Image](http://marcharrington.co.uk/banner2013.png)
View Worklog
Do you mean the fender? I did that (briefly) - but it seemed that the frame would be in the way and somehow the nut is tacked on the inside of the hollow frame.......
