Full Shifter Bushing set.
Hey,
So ive needed bushings for like months.. and got a new shifter and need em asap
Talked to Pigon off Imazda but hes going to be a few weeks..
any help or suggestions would be great. thanks.
-Josh
-Josh
1996 MX-3 GS - rollin' on Rota Slipstreams, (Red, Deep Tint, Black Lip)
True Straight Neck KLZE with TB relocate. Custom Cold air Intake. 2.25 Exhaust to Bosal muffler.
ACT Stage 2, Fidanza Lightweight Flywheel, Short Shifter with CorkSport Bushings and SS Clutch Line.
Suspension Techniques Springs On Zx2 Struts. SRD Control arm Bushings, Custom Sway Bar Links
- Kirk95gs
Re: Full Shifter Bushing set.
corksport bushings.
http://corksport.com/store/category/53f ... train.html" onclick="window.open(this.href);return false;
Good price and shippings not that bad.
thanks guys, Order them, along with SS clutch line..
I have used the bronzeoil ones as well as a set of nyloil ones I got from a company on ebay
they were slightly cheaper and just as effective, although they arent always available
|Bryan|
I got me a SPI....
I got me a SPI....
I keep hearing about the SS clutch line. Is there a problem with the MX3 clutch line?
Stainless Steel imporves clutch feel due to the fact that it has a much higher wall strength and will not deform when under pressure.
you wont really notice much difference in my opinion
I have had an ss line with a stock clutch as well as a spec stage 2 plus with a lightened pressure plate
piece of mind I guess really![Smile :)](./images/smilies/icon_smile.gif)
|Bryan|
I got me a SPI....
I got me a SPI....
Others have said the difference was significant. I think if you're not expecting much and you notice any difference at all it seems bigger than it is. I agree that it will probably not blow your mind...especially if you're expecting it to.
