air/fuel gauge connections
- zzzoomx3
with my Glow shift A/F gauge - which 02 wire should i tap into? i just put a post on Glowshift - but i figured someone here might know too....
- spidy53red
Re: air/fuel gauge connections
I'm having that same problem i just get my A/f meter and don't know how to connect it. If you find out anything let me know.
hgallegos915
U got a wideband?
-hec
- johnmx3ze
hey i have the same gauge i was just wondering if you found how to connect it???zzzoomx3 wrote:with my Glow shift A/F gauge - which 02 wire should i tap into? i just put a post on Glowshift - but i figured someone here might know too....
one is postive one is negative.. the other is the sender ..which you connect to the sender on your o2..either at the ecu or the actual o2.
- johnmx3ze
on which wire of the ecu???96mx-3 wrote:one is postive one is negative.. the other is the sender ..which you connect to the sender on your o2..either at the ecu or the actual o2.
- WhiteFinish
Middle plug, Upper row, 2nd wire from your right (big white wire)
