Self locking nut removal
cando123
Post by cando123 »
Is there a special tool required to remove a self locking nut? Trying to seperate the header pipe from the cat and i can't get it to budge.
fowljesse
Re: Self locking nut removal
Post by fowljesse »
If penatrating oil doesn't work, try heating it up w/ a propane torch.
Kirk95gs
Post by Kirk95gs »
cando123 wrote:Is there a special tool required to remove a self locking nut? Trying to seperate the header pipe from the cat and i can't get it to budge.
just cut it and by new bolts.
sk8erdude802
Post by sk8erdude802 »
Kirk95gs wrote:just cut it and by new bolts.
Hes correct. even if you get one to go there will be atleast another one that just plain snaps. Its almost welded on there because of the extreme heat.
Steve-O
93' MX-3 GS SE ZE - Sold to Acheron1502! SOLD!!!
93' MX-3 GS SE - R.I.P. K8 with Integra CAI, HEI mod, Koni inserts with H&R's,drift kit, Kicker KX400.1 and KX200.2 amps, 2 kicker 12s, set of 6x9's. Custom trunk enclosure
MyFeedBackThread
^^^^^ Click on image for my work log ^^^^^
PushnFords
Post by PushnFords »
A guy I used to know always said "Loosen by tightening!". If you try and loosen bolts or nuts in exhaust like that they'll often get halfway off (and be a PITA through every turn) and then break. So just tighten them until they snap...only takes about a half turn.
If you use a torch...get MAPP gas. Burns a lot hotter than propane.
Here's another trick. Penetrating oil just burns off if you are using heat. Get a REAL wax candle and when the bolt is hot stick the candle on it. The wax will flow between the bolt and nut and come out easier. Lots of engine rebuilders use that method for oil galley plugs and such that have been in place forever.
Derek
sk8erdude802
Dude your killin me. This is like the third post from a month ago youve dug back up. LOL. Im just messin with ya. Welcome to the forum pushnfords
Steve-O
MyFeedBackThread
jason5151
Post by jason5151 »
just cut it !
1996 mx-3 black 1.8 v6
fowljesse
Post by fowljesse »
That wax idea is a good suggestion, though, for sa bolt you can't easily replace.
I like "zombie" threads, as long as there's good new info.
