n e suggestions on what brand i can use?
STRUT BARS...
Shu_Hayate09
STRUT BARS...
i bought some strut bars.... and the front one doesnt fit... cause my KLZE is too big
'92 MX-3 GS - KLZE, K&N SRI, Tokico Shox, H&R Springs, TSW 17"'s, full SE interior
'09 Mazdaspeed 3 - Fujita CAI
- fowljesse
Re: STRUT BARS...
You can use the 1 you have, if you put washers under it. I'd suggest making a shim the same shape as the mounting plate, if you can, but washers work, or you can bolt it on top of the existing bolts. Just make sure it clears the hood, and it may touch the sound/ heat shield.
