Shorter rear springs than H&R?
fowljesse
Post by fowljesse »
I have H&R springs, and the rear is notably higher. Should I cut them?
Just Kidding!!
Are there springs that are .5 in. lower than H&R?
umcamara
Re: Shorter rear springs than H&R?
Post by umcamara »
Yeah...I've got the same springs and the same issue. I look at other cars on the road and envy how the front and back are level, regardless of how low they are.
Its seems most of the lowering springs available for the MX-3 provide more of a drop in the front than in the back. Why? I don't know. I think it's pretty gay.
You might be interested in the Intrax springs. They are supposed to give a 1.75" drop to the front and back. But they're designed for the V6. (Which I now know that you have after going back and reading your sig.) I don't know how great of an idea it would be to use one brand of spring on the front and another on the back. Might consider the Intrax all the way around. Hopefully someone else can comment on their experience with Intrax springs.
Another obvious option is the Ground Conrol Coilovers. Set the front and rear just as low as you want them.
'98 BMW 328is M-Tech
Feedback Thread
Post by wytbishop »
The Eibach springs are slightly shorter. My black 94' sits real nice with them. I don't know how they compare to the H&R's for ride quality...but I find them just a little stiffer than stock. I wish I had gotten the MX-3 springs rather than the Escort ones, but they're not bad at all.
umcamara
Post by umcamara »
So you're saying the Escort Eibach springs are shorter? Because I'm pretty certain that the MX-3 Eibach springs provide less of a drop than the MX-3 H&R springs, which is what I have.
Feedback Thread
95 rs
Post by 95 rs »
my b&g springs gave a really level drop.
Post by wytbishop »
umcamara wrote:So you're saying the Escort Eibach springs are shorter? Because I'm pretty certain that the MX-3 Eibach springs provide less of a drop than the MX-3 H&R springs, which is what I have.
I never had a chance to compare the Eibachs and the stockers side by side, so I don't know if it's the springs or the combination of springs and struts, but my drop was perfect. About an inch front and back. Just enough to center the wheel just right.
umcamara
Post by umcamara »
Fowljesse... Do you have H&R's for the Mx-3, or the Escort? Mine are for the Mx-3.
Feedback Thread
fowljesse
Post by fowljesse »
Mine are for the mx-3, too. I stripped everything out of the rear, and thought maybe that made it raise up.
I'm totally happy with the ride. I just don't like the way it looks.
umcamara
Post by umcamara »
fowljesse wrote:Mine are for the mx-3, too. I stripped everything out of the rear, and thought maybe that made it raise up.
Wait a sec, is the rear lower on your car???
Feedback Thread
fowljesse
Post by fowljesse »
Haha. Naw.... I thought that SINCE I took weight out, the back is now higher. That still doesn't seem clear. The back is about .5" higher than the front right now, and I thought it was because of the weight I took out.
umcamara
Post by umcamara »
No...I see what you're saying now.
Feedback Thread
IrishNinja
Post by IrishNinja »
95 rs wrote:my b&g springs gave a really level drop.
How low are your B&Gs, and where did you find them?
My B+G's didn't give me a level drop, my rears were almost tucked into the fender. My H&R's gave me a level drop; my front is just a tad lower, and my rear is a bit highter.
