[FS] MSD, Mallory, AEM, OEM, Dynomax, Rockford Fosgate
2) EFX Digital Positive Power Terminal - $15 Shipped
This has 4 inputs.... 1- 1/0awg, 1- 4awg, 2- 8awg. It also has a Digital LED readout of your Voltage.
-) EFX RCS Cables (6ft) - $20 Shipped
Brand new in the package. Never used them as was planned. Superior sound qaulity.
3) Niehoff Distributor Rotor Brand New - $15 Shipped
This is for the KL/K8 Distributor, 93-94 Probe, MX-6, 626, and 92-93 MX-3
4) Mallory Ignition Coil Wire - $12.50 Shipped
Coil Wire Kit - 2.5 ft Unassembled, 1 Female Socket (Standard) Distributor Boot & Terminal, 1 HEI Distributor Boot & Terminal
5) NX -6an "T" - $20 Shipped (Each) - $30 Shipped For Both
Can be used for fuel systems and nitrous systems.
6) 45 lb Injectors - $50 Shipped
These are brand new for a set, do an extra injector mod or for a custom project.
7) MSD Power Tower and Universal 90 deg Boot - $10 Shipped
These are brand new and never used, perfect for the external coil mod on the KL/K8 Distributors.
KLZE Pistons/rods - $80 Shipped
These are used but pulled from a running motor, All 6 sets included. All pistons and rods are in great condition, and still attached to eachother.
9) Dynomax Turbo Muffler - $40 Shipped
2.5" straight through muffler design. Had this on my KLZE MX-3 with nitrous and sounds awesome. Flows more than enough for you turbo guys.
10) KL/K8 Starter MTX - $25 Shipped (Each)
I have 2 startes in prefect working order. If you need one or think you might soon, snag one up for a back up.
11) Rockford Fosaget 250.2 - $80 Shipped
2- Channels @ 125 Watts @ 2 Ohm
12) Rockford Fosgate 8" DVC Subwoofer - $75 Shipped
Wanna be light and have some bumps, this is a nice sub that can really thumb for its size. Easily hidden behind front seats. Dual Voice Coil, Max power of 800 Watts. Really heavy duty sub.
13) Autometer Universal Guage Pod - $20 Shipped
Made to mount 1 2-1/16th gauge. Can mount anywhere.
15) Nokya Carbon Fiber Shift Knob - $15 Shipped
Carbon Fiber and Chrome finish. Will screw directly on a MX-3, MX-6, Probe Shifter
16) MX-3 Speed Sensor MTX - $20 Shipped
Pulled from a working transmission
17) OEM Strut Mount Bearings - $20 Shipped
Will fit the MX-3, MX-6, or Probe Front strut mounts. Is your car making a clicking noise when turning these are the culprit.
18) OEM Probe Oil Pressure Sender - $10 Shipped
In working order, replaced with aftermarket oil pressure gauge.
19) OEM Mazda Front Valve Cover Gasket - $10 Shipped
This is used but not for more than a month, and the motor was pulled and parted out. I no longer have the car. Gasket is pliable and flexible.
20) NOS 3an Line (3ft) - $15 Shipped
In perfect working order, Anodized Blue
21) Custom 4an Oil Line - $25 Shipped
Bought new from local supplier for my KL-Turbo project. Perfect length from the block to turbo.
22) OEM Alternator Tensioner and Bracket - $20 Shipped
Free spinning, and in good working order.
23) OEM PowerSteering Tensioner - $20 Shipped
These are common to breaking, This is in full working order.
23) OEM KL/K8 Pilot Bearing - $10 Shipped
This is a free spinning bearing that is a must have when changing your clutch. The bearing is used but practically brand new, i got this with my ACT clutch kit and then bought a Clutchmasters Kit.
24) OEM Clutch Dust Shield - $10 Shipped
Not bent, or broken. Just a lil dirty.
25) OEM Rear MX-3 Motor Mount - $30 Shipped
This is filled but still pliable, good medium for a solid mount but still movable for the comfort
- mx3autozam
Re: [FS] MSD, Mallory, AEM, OEM, Dynomax, Rockford Fosgate
I think I need a speed sensor. at the top were the wire goes in its like some mushy soft plastic. Mine kinda chipped away and stuff. I'm sure it probably still works.but i want one thats good. But whats the condition of yours. Can you get me a pic of it showing the top. If its all intact I will paypal ya 20bux.
93 Mazda MX3 KLZE Turbo
$20 Shipped is in the Continental US...So for shipping to Canda Will be slightly more, i would have to actually get a quote as to not charge u too much and not short myself.
- mx3autozam
hey man. tahts good...definitly in alot better shape than mine. I'll pm you my address. its the same one you shipped the lsd too.
hey do you have a cross memeber let me know email me at fromtornashes@gmail.com" onclick="window.open(this.href);return false;
RIP Matt
Yes i have both front to back and side to side. Which one you need?
oman I wanted a speedo sensor as my wires broke off on mine, o well I don't need to know how fast im going anyway:) good luck on the sales slammed
Teal 1993 MX3GSZE
Speedo is still for sale. . . . . . no one has paid for it. I'll PM you if you don't check back here.
Anything else anyone wants?
List a part and i probably have it in my storage.
