KLZE swap exhaust
KLZE swap exhaust
Im doing a KLZE swap into my 1992 gs mx3. Do I need custom exhaust or can I order some ebay probe headers and have them fit right to my old exhaust system. THanks for the response guys.
Re: KLZE swap exhaust
yes, probe headers or mx-6 headers will fit.
The cat will have to be moved back, or taken out.
cant you just use stock headers? dremel ports to flow better? much of a difference?
1996 MX-3 GS - rollin' on Rota Slipstreams, (Red, Deep Tint, Black Lip)
True Straight Neck KLZE with TB relocate. Custom Cold air Intake. 2.25 Exhaust to Bosal muffler.
ACT Stage 2, Fidanza Lightweight Flywheel, Short Shifter with CorkSport Bushings and SS Clutch Line.
Suspension Techniques Springs On Zx2 Struts. SRD Control arm Bushings, Custom Sway Bar Links
- Kirk95gs
Stock headers eh.. Stock exhaust manifold. The stock manfiold is way more restrictive then aftermarket headers, there would be no way to you a dremil to port it out. and for the price of headers now.. you can't go wrong.
