squeaky??
Posted: February 27th, 2008, 7:06 pm
by chertel
When I drive slowly around a corner left or right there is an annoying squeaking coming from my front tires?? Does anyone know what it could be?
Thank you
chris
Re: squeaky??
Posted: February 28th, 2008, 5:03 pm
by bp_turbo94
squeaky or clicky?
Re: squeaky??
Posted: March 3rd, 2008, 6:49 pm
by chertel
Squeaking only when moving slowly around a corner, it is coming from the driver side. It only happens when in motion. I dont think it is the breaks but that is what it sounds like. And it only makes noise when it is warm outside? I took it to a mechanic and he took my car for a spin and couldn't guess what it could be so I made an appointment with him for next week and he will take the wheel of and see what it could be.
thanks
Re: squeaky??
Posted: March 4th, 2008, 9:19 pm
by mxer666
strut mount, outer tie rod, inner tie rod. it has to be something that moves as you turn. Or something that recieves pressure as you turn.
Re: squeaky??
Posted: March 9th, 2008, 9:01 am
by SuperK
if it's a creaking sound, like the creaking that happens when... you're rocking the forest ;)
then it could be strut mount, control arm bushings, it could be the inner cv joint.
if it's an actual, "squeak, squeak, squeak" that happens with the rotation of the wheel, then it's your calipers, they're sticking.
Re: squeaky??
Posted: March 9th, 2008, 1:11 pm
by 94mx3precidia
it could be the dust shield that is rubbing against the rotor at low speeds.
