Hey can anyone give me the spline counts of the axles? I really just need the outside spline (part of the axle that goes in the hub) but the inside spline counts would be nice to know anyway
please please help if you can
Axle spline counts?
Axle spline counts?
ProjectMx
My BP and AWD build thread
Cardomain
93 Escort GT daily driving
Cardomain
- mx3autozam
- Limegreen mx-3
Re: Axle spline counts?
he means the spline count that goes into the hub where the axle nuts bolts on too
regardless if its a auto, 5 spd, 4cly f or g series trans or v6 trans the hub spline is the same..
why well i have a former 92 mazda mx-3 1.8 V6 that now resides a boosted 1.6 sohc with a modified mazda g-series trans and axles..
now the spline counts that inserts into the trans itself are all different from auto, 5 spd, 4cly f or g series trans or v6 trans
4 cyl is what i need but like he said the outside splines are the same i just don't know what the number is. if anyone can give me the number or where to look please do
ProjectMx
Cardomain
Cardomain
there was a thread about transmission interchange on here. can't find it now tho.
from memory of that thread,
F series has 20 spline
G series has 22 spline
1995 MX-3 1.6 DOHC 5SP.
so AWD spline must be 24 or 26
thanks a ton!
thanks a ton!
ProjectMx
Cardomain
Cardomain
on rockauto.com i found this out
mx3 1.6
left side: outboard spline 26 inboard spline 24
right side: outboard spline 26 inboard spline 26 & 2 blank
Protege LX
left side: outboard spline 26 inboard spline 26
right side: outboard spline 26 inboard spline 24 & 2 blank
Protege 4wd
does anyone know another place that tells spline counts? and what is the 2 blank? is that the metal clip that goes around the axle and kind of clicks it into place? if it says 2 blank there are two clips and no mention means only one clip?
mx3 1.6
Protege LX
Protege 4wd
ProjectMx
Cardomain
Cardomain
Looks like you found the right numbers. The ones I posted above are clutch spline count. haha
