sweet...so I 've been going to surrey a lot...the roads there are really shotty on my suspension...but they all seem to be concentrated on the right side (I still cant figure out why..(all the sewer drain caps...all the bumps and pot holes) so as a result my passenger side wheel shakes like its gonna fall off and on left turns (when I put pressure on the right wheel) there's a *knock knock knock* sound.
My question is ...is this a CV problem?
Question about lateral movement on wheel
- cabriolet
* White 92 MX3 GS * +bone stock K8+ NGK Iridium Plugs + 10.2mm Iridium wires + RAZO shift knob + 8000K HID kit + grant steering wheel [wtb] white fenders
Re: Question about lateral movement on wheel
Yeah, sounds like your outer CV joint on the right is going bad.
