Intercooler to Cold Air Intake
- MX3-Life
I'm thinking about buying a Intercooler for my 94 MX3 GS and until i get my turbo i want to connect it to my Cold Air Intake System... I think it will increase the HP by some but not alot. Any thoughts on this? Or should i just wait awhile till i got the Turbo and if anyone has a good place to buy Intercoolers for a 94 Mazda MX-3 GS links would help alot thanks.
- ElectricEnergy
Re: Intercooler to Cold Air Intake
It'd be easy enough to do, but I wouldn't bother. You won't see any power gains. An intercooler doesn't actually make air colder, it just makes it closer to the same temperature as the air outside the car. This is a big advantage with turbochargers because they heat up the air significantly. A cold air intake should already be drawing in the coldest possible air from the atmosphere.
The temperature that the air drops to after passing through the intercooler doesn't have a huge effect directly on power output. It allows you to increase your boost even more without detonation, thats where the real power gains come from.
If you install the intercooler without a turbo, all your going to do is reduce your throttle response.
I definitely suggest reading "Maximum Boost" By Corky Bell before piecing together your turbo setup. Before working on my friends Turbo Silvia I read it cover to cover and I learned a lot.
David
David
![Image](http://i159.photobucket.com/albums/t148/electricenergy_album/caravatarcopy.jpg)
KL-ZE Swap - OBX SS Headers - 2.5" Exhaust - Falken Azenis Tires - H&R Springs - ZX-2 Struts - CAI - Front & Rear Tower Bar - AWR Motor Mounts - 100hp wet shot (yet to be tested)
- tehbrookzorz
You're just looking for an excuse to test-fit your intercooler, aren't you? haha.
Cody
![Image](http://i.imgur.com/Q0Vh17N.jpg)
Sounds something like what a RICER might do
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- se7en
well, I think that it would be funny to do....
kinda like the fake BOV's people put on there exhaust tips, and electric superchargers!
mad v3tc yo !!!1
!!11!!11!!!!one
!!!!111
fast and flimziest.
heh.
it isn't such a bad idea to test fit it though...
why not![Smile :)](./images/smilies/icon_smile.gif)
7
ps. it will give you 500whp just like the civics guys get.
mad v3tc yo !!!1
!!11!!11!!!!one
!!!!111
fast and flimziest.
heh.
why not
7
- Flinch
Hey man i thought long and hard on this subject because i wanted to do an NA build. I was going to incercool my cold air intake than spray it with CO2 from a remote line. Adding an intercooler will decrease throttle responce and power, its meant to have air forced through it not sucked through as the motor demands. it woould be like you trying to breath through a straw that is a foot long, than try breathing though a straw that is 2 feet long. the 2 foot straw is better when air is forced through it because it gives the air a longer period of time to cool down plus you are increasing the flow and the velocity.
-KL31 stock internals with curved neck intake manifold and KL36 ecu
-Turbo running 7.5psi
-FMI 3"x12"x32" all alluminum and welded, have a 7.5 PSI spring she just creeps on cold nights
-ACT 6puck sprung/96 probe tranny
-Short shifter
-HEI and MSD 6al (makes a big difference when you spend the 65$ ont he right spark plugs)
-KYB GR-2 struts with H & R springs
-Megan racing seats
-Personal 280mm stearing wheel
-Familia rear strut tower bar
-Short shifter
-Megan racing seats
- 93MX3KLZE-T
It would be a bad idea.
93 MX-3 GS, KL-ZE, T304E ***SOLD***
221.9 whp 219.0 wtq @ 5 psi untuned
13.4 @ 108 mph
13.4 @ 108 mph
- tehbrookzorz
Or... You can go on ebay and buy one of those intercooler intakes. search it on ebay.
If I was you I wouldn't do it, because for one, it's pretty rice and two.. i just wouldn't do it.
![Image](http://i138.photobucket.com/albums/q249/blakeab84/smoothmx3x75-1.jpg)
--- K8 was my gateway drug.
hahaha ah man i had a good laugh.tehbrookzorz wrote:
1993 Mazda MX-3 GS, V6 KLZE 2.5L, CenterForce Duel Friction Clutch, Nylon Shifter Bushings (from Imazda.com), Integra Cold Air Intake, Millenia Intake Manifold, Indigo Gauges, Pacesetter Header->Resonator->2.5" piping->Dynomax Muffler, VSX Front and back bumpers from FX Designs, AWR Front and back Motor Mounts.
- se7en
heh. that would work awesome! all people should get one of thosetehbrookzorz wrote:
oh oh...I think my vtec kicked in....YOOOOOOOOO.
- tehbrookzorz
MX3-Life wrote:Thats the intake on God's Car.
No, I think you're wrong....
![Image](http://i213.photobucket.com/albums/cc191/kisselvw/P1000376.jpg)
Cody
Are you serious?
Please tell me that was photoshopped and it's not forreal?
The things people do... lol
