KL-DE compatible with K8 trans?
Posted: January 17th, 2008, 12:17 am
by jhendrix
I'm wondering if the klde motor out of a Ford Probe GT is compatible with either the K8 1.8 V6 transmission, manual or auto?
Thanks!
Re: KL-DE compatible with K8 trans?
Posted: January 17th, 2008, 1:02 am
by Smith18
should be. the engines are identical from the outside?
Posted: January 17th, 2008, 4:29 am
by Aston Wards
Yup, it'll bolt up to either just fine, but it isn't recommended to use with the atx
Posted: January 17th, 2008, 9:43 am
by Mnemonic
considering the probe gt uses the same transmission as the manual mx-3 gs.....
Someone didn't bother to search
Posted: January 17th, 2008, 10:50 am
by the_anj
As the others have already said, it'll work just fine. I'm using my stock mtx with a DE and it works perfectly
