I'm wondering if the klde motor out of a Ford Probe GT is compatible with either the K8 1.8 V6 transmission, manual or auto?
Thanks!
KL-DE compatible with K8 trans?
Re: KL-DE compatible with K8 trans?
should be. the engines are identical from the outside?
1993 Mazda MX-3 GS, V6 KLZE 2.5L, CenterForce Duel Friction Clutch, Nylon Shifter Bushings (from Imazda.com), Integra Cold Air Intake, Millenia Intake Manifold, Indigo Gauges, Pacesetter Header->Resonator->2.5" piping->Dynomax Muffler, VSX Front and back bumpers from FX Designs, AWR Front and back Motor Mounts.
- Aston Wards
Yup, it'll bolt up to either just fine, but it isn't recommended to use with the atx
91 Eunos Presso KF-ZE
89 Nissan 300ZX TT 2+2
90 Nissan 300ZX TT 2+0
![Image](http://i2.photobucket.com/albums/y20/ViciousZ32/carbanner.jpg)
considering the probe gt uses the same transmission as the manual mx-3 gs.....
Someone didn't bother to search
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
As the others have already said, it'll work just fine. I'm using my stock mtx with a DE and it works perfectly
'94 GS-DE
