Extended Wheel studs. CAnt find listing for the MX3..
so which ones will i go for. the miata ones? or the civic will work wont they? im mot concerned about the knurl size. i know the thread pattern is 12x1.5 but im just not quite sure which studs will work wit the mx3 since i cant find them on APR or anywhere.I believe miata ones will work wont they? I'm just going to do my wheel bearings while im at it also. thanks for any help!
2004 Subaru STi
1993 Mx3
1993 Mx3
- tehbrookzorz
Re: Extended Wheel studs. CAnt find listing for the MX3..
I had once figured it out, but I'll have to find the part number again in the summer for my spaced-out wheels. Papco and Felpro should make them, if I'm not mistaken. It's just a matter if figuring out stock size, then going a bit longer. A good parts guy with a book should be able to figure it out for you. Post your findings unless someone else posts first.
Cody
![Image](http://i.imgur.com/Q0Vh17N.jpg)
im pretty sure u can use these from summitracing.com ARP-100-7708 . thats wut my buddy on clubpro came up with and is runing them on his BG . also PRDonline has them also http://www.prdonline.com/catalog/pro...roducts_id=456" onclick="window.open(this.href);return false; thanks to CLUbPro!
2004 Subaru STi
1993 Mx3
1993 Mx3
