Will a 93 probe tranny fit in my 93 mx3?
I have a 93 mx-3 I4 5spd and was wondering if an I4 5spd tranny from a probe would fit. Thanks ![Very Happy :D](./images/smilies/icon_biggrin.gif)
Re: Will a 93 probe tranny fit in my 93 mx3?
no, Only the v6 manuals are swappable, if you have an mx-3 rs with the b6 motor and you need to replace your tranny you want to use the protege lx transmission
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
How do I know if it is a b6 or not?
well if you have a rs mx-3 then you have a b6 if you have a gs mx-3 you have a k8, since you said you have an i4, then you have a b6, the protege lx uses a 1.8 bp motor but there trannies bolt up to the b6 and its a better tranny
Hey, that helps me a ton, but will a 1.5L Protege tranny fit too?
- jaydog5678
It will. It has to be from a second gen Protege.greencutters wrote:Hey, that helps me a ton, but will a 1.5L Protege tranny fit too?
Or an Escort GT, also the same tranny as the Protege LX.
No more MX-3
2005 Hyundai Tiburon GT
95 F-150...6" lift, 35" tires
- jaydog5678
If you did this, you have to use Escort/Protege axles, clutch, flywheel, and modify the halfshaft to mount to the back of the B6 block. It's much easier to use another F series transaxle with less headache.Raven95150 wrote:Or an Escort GT, also the same tranny as the Protege LX.
