i might have an ac leak as i found some sorta oily substance on an ac pipe and air pipe below it.
the pipe is the one from compressor to the drier and the spot is where the black rubber pipe is connected with a metal connector.
is there a substance that can reseal this?
like cold weld or jb weld?
Thanks
ac leak
- cyclonekid78
Nope you need to evacuate the system and replace the rubber seal.
93 RS BPTurbo
http://www.cardomain.com/ride/2628805" onclick="window.open(this.href);return false;
- cyclonekid78
That means you need a new line.
93 RS BPTurbo
