running lean.
Posted: December 13th, 2007, 1:42 pm
I am running lean.
I am wondering what I can do to fix that.
I have FMU installed, and I am still waiting on my millenia S injectors to get here.
at cruise(part throttle, I am at 11.8-12.2:1 which is great, and at idle, I am at stoich(14.7:1)
but as soon as boost comes on, it goes lean(like way lean, and off the gauge.
I am wondering, Do think the millenia S injectors will fix this? could my stock injectors just be sh!tty?
without the fmu, I can't boost over 1 psi before it goes lean.
now I am at about 2-3psi, and still lean there.
I am hopeing thast the millenia S inj. will let me boost to 7-9psi.
what do you think???
will the millenia S 's fix my prob or what?
thanks
7
EDIT : it is the worst in first and gear.
third gear will pull about 13:1 until 3-4psi, then go way too lean.
and forth gear is not bad until about 5psi.
geez, I can't wait until my injectors get here. I hope that fixes my problem.
thanks
7
