Brake booster check valve
Posted: December 7th, 2007, 8:52 pm
by slimmyslim1420
Does anyone know a website or place where I can get a 2nd generation rx7 brake booster check valve?
Posted: December 8th, 2007, 7:42 pm
by se7en
doe sit have to be one from that car? why not a universal one or the stock one in the mx-3??
7
Posted: December 8th, 2007, 8:21 pm
by slimmyslim1420
Well there was a discussion on here a while back about it and it was said that the one off the 2nd gen rx-7 was the best one to use for the turbo v6 set up. They said the universal one didn't do something that the rx-7 one does and it can handle more than the stock mx-3 one. So I am trying to find one.
http://www.mx-3.com/phpBB2/viewtopic.php?t=51373
Posted: December 16th, 2007, 12:27 am
by nolig2278
i installed a 1 way check valve from a boat shop that is good for 200psi and i think made of brass
less than $20
Posted: December 17th, 2007, 6:48 pm
by hppwdn
I have a Millenia brake booster hose on mine. It's been boosted for well over a year and I'm having no problems with it. Regularly running 12psi, it's dyno'd at 18psi with no problems.
Posted: December 17th, 2007, 9:42 pm
by XxantwawnxX
I just used the stock valve.
Posted: December 18th, 2007, 6:09 am
by hppwdn
I switched to a millenia one a long time ago when I put on the millenia IM. I think the stock K8 one would probably work too.
Posted: December 18th, 2007, 2:07 pm
by hgallegos915
im loosing brake fluid as i boost :/ wtf... lol
no brake line leaks.. its like if its coming out .. i dont have a check valve.. do i need it?
Posted: December 18th, 2007, 3:46 pm
by XxantwawnxX
hgallegos915 wrote:im loosing brake fluid as i boost :/ wtf... lol
UNless you changed the original hose that goes from the mani to the Brakebooster then it should have a stock valve in there already. Thats what i use, a lot of people opt for a stronger one.
Posted: December 19th, 2007, 3:41 am
by hgallegos915
noo mine doesnt have it o.0 i did change the hose.. i think its never had it..
Posted: December 19th, 2007, 10:48 am
by XxantwawnxX
hgallegos915 wrote:noo mine doesnt have it o.0 i did change the hose.. i think its never had it..
its inside the stock hose..u cant see it..but u can feel it.
Posted: December 19th, 2007, 1:35 pm
by hgallegos915
i changed the hole... ill get one.. from a millenia right? is it like a pcv valve? wow this would explain why my fluid dissapears? o.0
Re: Brake booster check valve
Posted: December 30th, 2007, 10:56 pm
by nolig2278
using the stock valve will cause high boost to blow past the brake booster and in my case it would blow into the passenger compartment
Posted: December 31st, 2007, 1:05 am
by hgallegos915
Im not using a valve... only thing is that my brake resevoir empties.. but where to? o.0 the manifold? i cant find any leaks inside the car.
