Brake booster check valve
- slimmyslim1420
Does anyone know a website or place where I can get a 2nd generation rx7 brake booster check valve?
1992 GS ZE swap 94 dash swap drilled and slotted rotors full ceramic pads CS SS clutch and brake lines KL-36 ecu zx-2 tokico struts eibach springs short shifter Tenzo exhaust Hi flow cat 2.5 in piping
- se7en
doe sit have to be one from that car? why not a universal one or the stock one in the mx-3??
7
7
- slimmyslim1420
Well there was a discussion on here a while back about it and it was said that the one off the 2nd gen rx-7 was the best one to use for the turbo v6 set up. They said the universal one didn't do something that the rx-7 one does and it can handle more than the stock mx-3 one. So I am trying to find one.
http://www.mx-3.com/phpBB2/viewtopic.php?t=51373
- hppwdn
I have a Millenia brake booster hose on mine. It's been boosted for well over a year and I'm having no problems with it. Regularly running 12psi, it's dyno'd at 18psi with no problems.
- XxantwawnxX
I just used the stock valve.
- hppwdn
I switched to a millenia one a long time ago when I put on the millenia IM. I think the stock K8 one would probably work too.
im loosing brake fluid as i boost :/ wtf... lol
no brake line leaks.. its like if its coming out .. i dont have a check valve.. do i need it?
-hec
- XxantwawnxX
UNless you changed the original hose that goes from the mani to the Brakebooster then it should have a stock valve in there already. Thats what i use, a lot of people opt for a stronger one.hgallegos915 wrote:im loosing brake fluid as i boost :/ wtf... lol
noo mine doesnt have it o.0 i did change the hose.. i think its never had it..
-hec
- XxantwawnxX
its inside the stock hose..u cant see it..but u can feel it.hgallegos915 wrote:noo mine doesnt have it o.0 i did change the hose.. i think its never had it..
i changed the hole... ill get one.. from a millenia right? is it like a pcv valve? wow this would explain why my fluid dissapears? o.0
-hec
Re: Brake booster check valve
using the stock valve will cause high boost to blow past the brake booster and in my case it would blow into the passenger compartment
Im not using a valve... only thing is that my brake resevoir empties.. but where to? o.0 the manifold? i cant find any leaks inside the car.
-hec
