brake rotor change
brake rotor change
How do I change the front brake rotors? Is it as simple as removing the caliper and pulling the rotor off? Or does the nut that holds the front axle on have to be undone?
remove tire, remove caliper, remove rotor
simple as that
- mitmaks
why are you changing them in first place, don't tell me you're going with drilled ones cause they're worse than you think. If your rotors are warped take them to local Napa, etc and they'll turn them for you.
- mitmaks
they warped in first half and hour, dude something is wrong with the way you're driving. You're not autocrossing every day are you lol
