almost broken part in motor didnt know where to put this
Ok so I got home today and opened my hood and I noticed this for the first time since I bought my mx-3 I have no idea what it is or what it does or if its really important, if anyone knows what it is and what it does let me know
If you cant tell from the pictures it seems to be detached a little not totally but I can move the plastic part around although there seems to be a wire or something on the inside, get back to me and thanks
it looks like a temp sensor to me.
its part of your motor so based on if your motor is a v6 or 4cyl you put it in those forums.
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- Tunes67
Definitely a temp sensor.. looks like for the SOHC 92-93 RS car. Not positive though.
Tunes67
Tunes67
- mx3autozam
It is either the sender for the temp gauge or for the Engine Computer so it knows what amount of fuel to inject. Disconnect it and if the motor runs like a dog it is the ECU. If not, the temp gauge. P.S. Tunes67 I have another question in 'head scratcher' if you have a minute. Cheers.
Craig from OZ.
- PATDIESEL
I think you need one from a four banger, but if a V6 will fit without leaking or crossing the threads it is fine.
it turns on the fan when it gets hot enough... you can finish breaking it if you want and there should be a small metal rod sticking out connect a wire to it and ground the wire and that turns your fan on all the time i did that all summer on my escort cause it broke during the winter you can leave it of usually and if it starts to warm up just hook it up. you could also wire a switch in the car to manually control the fan using that
ProjectMx
My BP and AWD build thread
Cardomain
93 Escort GT daily driving
Cardomain
ProjectMx
Cardomain
Cardomain
ProjectMx
Cardomain
Cardomain
ProjectMx
Cardomain
Cardomain
ProjectMx
Cardomain
Cardomain
- 94mx3precidia
