Turbo video
Turbo video
http://www.youtube.com/watch?v=_BugLULEkVU
I couldnt wait .. sorry..
so its at 5 psi.
My af ratios stay at around 13 .
Idle is 10... If i bump it ill run lean high so i decided to be rich instead of lean.
I could not drive, control torque steer and record at same times sorry.
1st gear and second completely spin , by when i get good tractin Im alreadt at around 50 mph.
0-50 was at 5 seconds.
Megasquirt is here. Ill install in a few weeks and tune it .
No more smoke.. the oil was old and was above level. It was getting into the return line.
Idles fine and drives fine.
Ill post a good video soon.
so its at 5 psi.
-hec
how much fun are you having right now? looks like a fair bit. put up another video! looks like a pretty quick car though
94 mazda mx3 rs 1.6l DOHC... probe 4-2-1 header, 2" catback, a spec CAI, advanced ignition timing, NGK plugs/ wires, obx light wight crank pulley
http://www.cardomain.com/ride/2754605/1
I have alignment issues... after 80 mph i start to shake .. ill make another video tomorrow.
by th way its smoking on start up.. bleh :/
lol it will do for now.. once the car gets rolling it goes away.. go figure :/
real turbo in a few weeks..
-hec
- mx3autozam
http://www.youtube.com/watch?v=S_AGTWmLhLY
shaky vid.. next time i promise ill have someone videotaping for me.. theres no way i can record and drive lOL
-hec
- XxantwawnxX
i taped the camera to teh steering wheel for mine
http://youtube.com/watch?v=IWQ3FYh7D1I
worked well might wanna try it. only thing is the tq steer moves the sterring wheel a little in the first few gears.
