Wierd box
WhiteFinish
Wierd box
Post by WhiteFinish »
I just wonderd whatfore a small box is.
The box is located under the coolent reservoir on the drivers-side.
It's bolted against the innerpart of the fender/chassis.
Also when you put your key in your contact you'd hear a clicking sound out of the little box.
Just wondering, who knows?
cstott282
Post by cstott282 »
the only little box i can think of is the small thing for the intake.. but u wouldnt hear a clicking noise from that
WhiteFinish
No, not the small intake that runs to the bottum of the battery.
But in thesame compartment
WhiteFinish
nobody?
Tunes67
Post by Tunes67 »
Pics?
Tunes67
I'm thinking ground point location ... but yeah without a pic... could be an aftermarket alarm or something...
Dali
Post by Dali »
might be a relay setup for lights, not something we would have over here. or its something aftermarket.
Whisper
Post by Whisper »
There are a couple of boxes down there that appear to be relays or switches of some sort. I think I know what you're talking about. They slide onto brackets mounted on the fender, right behind the headlight. I had to relocate them when shoving the air filter down there. I don't know what they're for, but they sure have a lot of wires going into their plugs. They're like little ECUs.
/edit
I think I found one of them.
http://www.mx-3.com/95manual/page.cfm?S ... PageNo=003
#3, ABS relay, right?
Dali
Post by Dali »
are you talking about the main fuse block?
Whisper wrote:There are a couple of boxes down there that appear to be relays or switches of some sort. I think I know what you're talking about. They slide onto brackets mounted on the fender, right behind the headlight. I had to relocate them when shoving the air filter down there. I don't know what they're for, but they sure have a lot of wires going into their plugs. They're like little ECUs.
/edit
AHA that would make sense... I forgot that the question came from the Netherlands... it seems like most mx-3's over there have ABS...
mx3autozam
Post by mx3autozam »
i had to move them abit to get a fulter in there. they are relays of some sort.I used to hear them click when I turned my car on. Not anymore, and the only thing that change don my car is no daytime runners and no abs. so i donno if its one of those or not. Daytime runner module is near the strut tower, but maybe its somehow linked to it.
93 Mazda MX3 KLZE Turbo
Dali
Post by Dali »
need pictures.
WhiteFinish
Yes !! That's the one
Indeed it's for the ABS (on your picture nr 3)
Does it has to be grounded??
Whisper
Post by Whisper »
I wouldn't think so.
Tunes67
Post by Tunes67 »
Curious.. do those boxes only come in cars with ABS brakes? Or do you find those in most cars and it only makes a difference if you have the sensors? Reason I ask is that my GS seems to have this box (I'll take a pic tonight and post it in this thread to verify) but.. doesnt seem to have any sensors down near the axles. It does however have both the ABS fuses installed.
Tunes67
