oil pan Gasket
Posted: September 4th, 2007, 11:50 am
by PWRD_BY_HKS
Is there a Gasket to it or just silicone to it
Posted: September 4th, 2007, 2:32 pm
by cstott282
silicone
Posted: September 4th, 2007, 2:47 pm
by Vanished
x2 for the silicon
Posted: September 4th, 2007, 4:32 pm
by PWRD_BY_HKS
Thanks feLlas my turbo project its almost done.
Posted: September 4th, 2007, 6:10 pm
by cstott282
no prob... good luck!
Posted: September 6th, 2007, 7:29 pm
by 94mx3precidia
i got a cork gasket for $10
Posted: September 13th, 2007, 9:19 am
by PurpleDinosaur
I need to do this as well...
I know this is like admitting to being 3/4 brain dead but...
The Silicone fix for a leaking oil pan... can someone post up a breif how to?
I'm thinking:
Drain Oil
Clean the shite out of the oil pan and mating surfaces (Brake Cleaner? )
When fully dry goop up liberally with high temp silicone and reintall oil pan?
Fully torque while silicone is uncured? Partially torque allow to cure fully torque?
thanks!
Posted: September 13th, 2007, 11:39 am
by 1992blazeredgs
I would not recommend a cork gasket. Just fix it right and drop the pan, clean the mating surfaces and than apply a nice thick bead of silicone to the oil pan and than precede to bolt the pan back to the block. Let the silicone dry throughly before starting the motor. Also be careful not to get any silicone on the screen of the oil pick up tube or you could result in a drop of oil pressure. I suggest checking the online manual also for torque specs. You do not want to over torque the oil pan bolts.
Nate
