Readings gone bad
Readings gone bad
hey guys im kind of in the dark on this one. i thought my multimeter was bad because i was getting some weird readings when i testing my maf, o2, and spark plug wires. heck even the distributor that i just got from autozone tested bad on the primary coil. and i have not even installed it yet. but we tested a 102v on our 120v power outlet but it had the lights on so thats about right, get a 1.5v from a AA battery and 12.6 from our batteries. i mean whats the odds of all these components being bad, most of them are new and un used especially the o2 sensor. getting a 16.8ohm reading when it should be 6ohms. getting a 1.56ohm reading on my coil. which means its gonna be getting alot more current then its supposed to. if you have any thoughts it would be greatly appreciated because i dont think our meter is bad. thanks
Jon
Jon
check yer meter
The resistance and voltage measurements on your multimeter are totally different circuits. The resistance circuit should have its own power supply, which could be causing your problem (keyword - could).
I would test the meter on a known resistor to see if it's reading correctly. Just because the voltage reads right doesn't mean the resistance will also.
GL,
Vol
GL,
Vol
- Tunes67
I'd also add here that cheap meters give cheap results. I have a cheap meter and I also have a Blue Point digital meter (snap on brand). The Blue Point meter is much more precise than the cheapy I got from Home Depot LOL. Long story short.. get a good quality meter if you dont already have one.
Tunes67
Tunes67
very true you get what you pay for most of the time. the one im using is a Actron CP7677 DVOM. its kind of old but its still going for 45 bucks on ebay. it seems to be good but ill take it down to when i go to auto class. see what the intructor says. thanks guys
Jon
Jon
- xboxlivemonkey
