My mx3 sense tells me its the timing?
Posted: August 19th, 2007, 5:47 am
Im working on my buddys car..
The car will just crank and crank try to start .
Only way to start it is to move the disty ALL the way down and it will start.
It will sputter when you floor it.
Replaced VAF, spark plugs, spark plug wires. crank position sensor, tps/ Checked all the wires and no shorts. Replaced the ecu (old one fried when there was a short in the crank position sensor.
Replaced fuel pump
Replaced fuel pressure regulator. I got spark in all 6 cyl. Plugs are in the right order.
Car is a 92 gs with the k8 in it.
I say its the timing.. havent checked with timing light yet(will do during the week)
Any input?
Replaced fuel pump
Any input?
