Im working on my buddys car..
The car will just crank and crank try to start .
Only way to start it is to move the disty ALL the way down and it will start.
It will sputter when you floor it.
Replaced VAF, spark plugs, spark plug wires. crank position sensor, tps/ Checked all the wires and no shorts. Replaced the ecu (old one fried when there was a short in the crank position sensor.
Replaced fuel pump
Replaced fuel pressure regulator. I got spark in all 6 cyl. Plugs are in the right order.
Car is a 92 gs with the k8 in it.
I say its the timing.. havent checked with timing light yet(will do during the week)
Any input?
My mx3 sense tells me its the timing?
-hec
- cyclonekid78
Sure sounds like timing. Either the tensioner broke, or belt is worn out. Double check with timing belt. Had the same problem with my BP. Go figure it was the last thing I checked.( jumped a tooth)
93 RS BPTurbo
http://www.cardomain.com/ride/2628805" onclick="window.open(this.href);return false;
- mx3autozam
- cyclonekid78
Broke= as in if it wasnt working right.
93 RS BPTurbo
2x timming belt jumped a tooth
Happend to me when changed the belt. Car hould still run but ONLY with the disty rotated to the max.
So, one week later, I had the time to remove it and applied the belt properly to the cams. ( the R one is not so obvious to point) Then it worked OK with the disty at midle position.
K8 running LPG (Liquified Petrol Gas)
