ok so looking at everybodys setups,
i can see most of you only have one fan and some of you even a civic radiator
my question is..... at 4 lbs do i need to upgrade fans or radiator, if a fan needs to be deleted wich one stays .... do i disconnect the sensor to keep it running constantly or will it work the way its suppoed to....
turbo cooling system (radiator/FAN)
- PWRD_BY_HKS
jdmx-3 KID OF THE ![Image](http://img118.imageshack.us/img118/8885/3kidkn5.jpg)
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
yup, you dont need the main fan, just simply wire the other to a switch. Easy stuff. I know people at 9 psi not having the main fan. Some people use slimline fans.
-hec
- hppwdn
I have 2 slimline fans.
- XxantwawnxX
I use 1 slim fan
