Is this wideband ok?EDIT I GOT IT!
http://store.summitracing.com/partdetai ... toview=sku
It says wideband..
now also they got some tohers for 300 which come with the o2 also and got numbers..
but basically is this good? comming from summit? it even comes with the sensor.
It says wideband..
Last edited by hgallegos915 on August 21st, 2007, 8:17 pm, edited 1 time in total.
-hec
scratch that. I got this but from summit.
http://www.dcsports.com/ViewCategory.aspx?CategoryID=67
Also got the bung with it. I THINK it comes with nthe o2 sensor. If not ill just get it... any particular place to mount it?
-hec
Anywhere after the turbo and before the Cat is fine. I've read from different sources that anywhere from 8-12inches downline from the turbo is best (for heat/accuracy reasons). I hope your front 3 and back 3 cylinders join before they go into the turbine, but if you have customs pipes and the turbine spins off just 3 cylinders (dumb, but I thought I'd clarify since ppl do it), make sure the sensor is placed after ALL 6 cyl have entered the exhaust stream or your readings will only be accurate for the 3 cylinders, not all 6.
1993 GS
-MS front -functional molded hood scoop
-MS molded sides-shaved antenna
-Civic projectors -New black paintjob
- Limegreen mx-3
AEM and Innovate Motorsport and FJO are one of the best widebands ya can get.. anything else ur on ur one.. i have seen all the in action and being around a bunch of turbo cars i recommend..
i prefer Innovate Motorsport they have very nice setups. not only that but the O2 senor is a VW 02 senor easy to replace when they take a shyt.. aem and fjo oh yeah ur going to pay for a replacement 02 sensor..
don't take my word for it ya can only afford what ya can afford..
- claude matte
i got this from a buddy of mine i thought it was a realy good read hope it helps http://www.newtiburon.com/forums/showth ... p?t=109436
http://members.cardomain.com/mx3mazda
http://www.cardomain.com/ride/3346603" onclick="window.open(this.href);return false; new pics
- mx3autozam
O WOW I got it an I must say I am impressed! It didnt specify if it comes with the bung and o2 sensor! Yea it comes with a sensor and the bung, I had purchased another one so I guess ill have a spare :/
Anywho the gauge is very nice itself. and only for 300 dllrs?! thats a steal!
-hec
- mx3autozam
you sure you need one....Don't your turbo pipes have a bung on the downpipe already..The turbo kits I saw before always had them and came with a plug incase you were not running a wideband.hgallegos915 wrote:O WOW I got it an I must say I am impressed! It didnt specify if it comes with the bung and o2 sensor! Yea it comes with a sensor and the bung, I had purchased another one so I guess ill have a spare :/
93 Mazda MX3 KLZE Turbo
Mine didnt
-hec
