95 precidia 4cyl
Posted: August 11th, 2007, 5:30 pm
by mx3_gp
I just bought this car. I really like it and want to do it all up, but where do i start. I has NO pick up and i would really like some more hp in the first couple gears espcially. Where should i start, or is it worth it to try on this engine?
would appreciate any opinions. thanks
sean
Posted: August 11th, 2007, 7:23 pm
by umcamara
Check out the 4 cylinder FAQ's, there's tons of info on this type of thing. If your mx3's a '92 or '93 it should have a 88 hp SOHC, and if it's '94++ it's probably the 105 hp DOHC. Regardless, not very much power.
One of the most popular ideas seems to be to swap in the Mazda BP engine. It has a higher stock power rating, and can be a relatively plug & play swap. Do some searching, and you will find all of what you're looking for.
Posted: August 13th, 2007, 8:01 pm
by mx3_gp
thanks i'll look into it. appreciate the direction.
