Guys, I have three seals which are coming away from the car - I guess the adhesive has got too old!
1. The rain gutter, on the RHS of the roof, has become disconnected at the back. (~6")
2. The rubber seal around the rear tailgate glass is coming away from the tailgate, down towards the spoiler on the LHS. (~6")
3. The rubber seal below the (incredibly small!) rear window (under the spoiler) is coming away from the tailgate. (~4")
My question is how do I re-stick these three problem areas in a way that won't ruin the car and mean, if I did have to get glass replaced etc. in the future, that I would not have caused myself major problems.
Thanks
Pete.
External seals coming away - need fix.
Stock '93 V6.
- PATDIESEL
The seal is usually too dry and unflexable to be reglued to their spots on hte body. However, you can try some window caulk for automobiles. It can be found at most any parts store. You need to hold the seal inplace the entire time the caulk is drying. Tape or a heavy object might hold it down, but for the best result you need to make sure it stays in place until the glue is absolutely dry. This also means no driving the car until the glue is dry. So read the cure time and plan appropriately.
- mazdamx3_89
