high pitched noise
Car Stereo/Alarm Discussions
xboxlivemonkey
high pitched noise
Post by xboxlivemonkey »
its only when i have my stereo al the way up to 30 ( its limit )
and its very annoying , i know its the wiring but how to i actually correct it
chew*
Post by chew* »
I'm assuming its a high pitched whine that increases in volume as you accelrate. 2 ways to fix it, run rcas down the oppsite side of the car that the power wire is on or buy a really really good set of shielded twisted pair rca cables.
For reference i run my RCA's next to a battery bank with 2 1/0 gauge wires right next to them and no whine noise. My rca's cost through my sponsor was in the $90 range. They retail for over $200
mr1in6billion
Post by mr1in6billion »
Why do you have your system up to it's limit? Either you are deaf, have your gains improperly set, or you don't have an amp (but i'm guessing if thats the case you have aftermarket speakers and the head unit can't drive them).
xboxlivemonkey
to chew * , i have no idea what you said lol
im new to cars
and i kinda understodd what you are saying
and to mr , i dont usualy have them high but i like to have my music very looud once in a while = ) not always
any way yea its a high pitChed whine
it stoped after moving the cables around but i want to make sure it doesnt happen again = (
chew*
Post by chew* »
Ok run the cables down the opposite side of the car that your power wire is on.
Or buy a better set of cables
Tunes67
Post by Tunes67 »
Last high pitched whine I heard in my car was the ex GF.. no longer an issue 8)
Tunes67
xboxlivemonkey
the noise came back , and it seems that my cabels look very bangged up
and i do not know how to set it up
any ideas ?? hehe
2fazed
Post by 2fazed »
Get a pair of quality rca's, If all else fails, you can also get a noise filter. I got a pair from Radio Shack, that just plugs into your rca's, it works miracles.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
I used to have a problem with high pitched noise and I got bigger power wire(4 gauge) and it fixed the problem. Also running your rca's down one side and the power wire down the other is recommended... Make sure your ground is right on the metal (scrape off paint if you need to).
Vanished
Post by Vanished »
I had a high pitched wine that was audible when the deck was off and faceplate wasn't even on.
I put a new amp and fuse in. Did the trick haha...
1992 Blaze MX-3 GS *R.I.P.*
1993 Blue 93 SE-ZE
http://www.cardomain.com/ride/2770987/2
Return to “Car Stereo/Alarm”
