ive got a 93 gs with 180xxx miles on it and recently its been smoking pretty bad whne i hit the gas the car has had one owner since 93 and he has all stock parts, only thing the car has had done was replacement parts over the years , same clutch from 93 too lol well when i got it the waterpump went and the timing belt was shot and when i took off the timing belt the pulleys and the MAF was bad so i replaced all of those and i got a mechanic to look at it he said that the reason its smoking is because i have an oil leak comin from the valve stems , i was wondering should i bother fixing the problem or should i just save up some cash and swap to a KLZE i hear good things about that motor
the car is leakin oil so bad that i got an oil change and a week later there wasnt any left in the engine which makes me think that its leakin else where and its more hassle to fix
what do you suggest
