Wanted 2 check the timing and the manual says something about shorting out 2 pins on the diagnosis thing b4 checking the timing, did this and the engine fan comes out whn i start the engine, checkd and adjusted the timing, which is 10 degrees when the pins are shorted but way off if i dnt short the pins out. Is this the correct way 2 adjust the timing?
also just 2 check, no1 cylinder is the back left one yes? when looking at the engine frm the front of the car
How to check the timing?
£125 V6, be on the road sooooooooon!
weird thing tho..., when we jump ten and ground.. we cant get the fan to turn on at all.. no matter how we move the tps. Maybe its a bad tps? The fan itself turns on when car warms up. I did notice his engine is SUPER hot compared to mine.. You touch it and you burn your hand. However I dont think thats the problem.
-hec
