BP swap question
- facko
BP swap question
everythings been going smoothly so far but the only problem ive run into that i hadnt heard anything about is with the lil brace that holds the axle that mounts to the block...sorry if thats a crappy description...but the bolts seem to be in a different spot on the BP block than the b6d. if i get the mount bolted into the spot on the BP block the axle doesnt go into the tranny all the way...am i missing something obvious or is there some work to be done here?
- atlantamx3
- Limegreen mx-3
ARe u going from B6 to a BP and are still useing ur orginal F-series trans.
IF so which engine did u have the sohc or dohc.
If u have the dohc then the halfshaft won't bolt up to the BP block ur going to have to use the passenger side axles from the sohc mx-3 in order to make it work.
im if im off the subject then disregruad what im saying. i had a very long night and im just waking up. LOL
- Limegreen mx-3
ur going to have to give up the halfshaft and use the very long single axle that comes from the 92-93 sohc MX-3.
