I will be using this as a starter intercooler.. would this do? I want to mount it on the side hidden.
http://s191.photobucket.com/albums/z139 ... =Inter.jpg
Will this do for starters? 4psi? Vacumm tested and its got no leaks.
Opinions on this intercooler?
hgallegos915
-hec
- XxantwawnxX
if u can get it to fit it should be fine. I used one similar till i upgraded.
hgallegos915
Thanks
Im almost there
w00
-hec
