Tell me what you all think. I picked up some Speedhut gauges and a new Sony deck for my red RS. Got a fairly decent color scheme going on, but I had a wicked idea to put a blacklight in my gauge cluster instead of the green-covered incandescant to light up the needles.
I like it! I've always thought about doing red... nice.... oh and you can pull out all the little "green covered bulbs" and take the green covers off and replace them with whatever color you want... I wouldn't recommend LED's because since it is on a dimmer switch it doesn't make them last as long... but definately change them out or take the green off!
Also have you modfied your turn signal lights yet? you can take the green transparent pieces out... get 2 coke bottle caps (if you want red) and cut them to the same shape - walaa you have red turn signals on your dash to match!
I actually did take the green covers off of the needle illumination bulbs to make them more white instead of green, but like I said, I still want to do a black light conversion altogether.
LEDs aren't affected by dimmer switches. As long as the forward current doesn't exceed the specification, they'll last forever (almost).
Haven't done anything with the turn signals yet, but I'll keep that in mind. I was thinking of some kind of red cellophane or something but didn't have enough time to get around to doing that yet.
