turbo manifold specs v6
PWRD_BY_HKS
Post by PWRD_BY_HKS »
Does anyone know the specs on it. I'm gonna custom make it but I need to know what size is the piping that runs up to the turbine all help is good
jdmx-3 KID OF THE Image
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
hgallegos915
Post by hgallegos915 »
or if anyone can get a blueprint i got someone that can make them.
-hec
n2ogsze
Post by n2ogsze »
You're not going to find a blueprint. Anyway, just make the up pipes that come off each bank the same diameter as the stock collectors. I THINK they are 2", not sure though. Easiest way is to measure. Merge the two pipes into a 2.5" pipe. As for your downpipe, just make it 2.5" due to room constraints. You can go 3", but it's not necessary unless you plan on big boost.
T61 powered KLZE
PWRD_BY_HKS
Okay but you are talking about steel hose or rubber hose. My question is how am I supposed to hook up my bov with a rubber pipe.
And also what is the proper order in which to place the Vaf. I'm not too sure where that goes like before or after the bov
VICTORIA RACING
PATDIESEL
Post by PATDIESEL »
You need to do some research on how to turbo your car before you spend alot of money or spend too little and blow your motor. Look at wikipedia or buy Corky Bell's turbo book- Maximum Boost.
hgallegos915
I dont think ive seen BOV hooked up with rubber hose, most ive seen are welded, im getting mine done when the time comes. cust weld.
-hec
mx3autozam
Post by mx3autozam »
hgallegos915 wrote:I dont think ive seen BOV hooked up with rubber hose, most ive seen are welded, im getting mine done when the time comes. cust weld.
i've seen in on a sr20det in a 180sx from a local tunings hop...kinda pathetic
Mnemonic
Post by Mnemonic »
I could blueprint them, i have certifications in mechnical drafting, and i have autocad on my computer, but i lack the parts so i wont be able to do that till i have my own set
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
PWRD_BY_HKS
See the reason why I want to do rubber hose is because the intercooler fits between fender wall and chassis where many run their cai. I see absolutly no point in but all this piping and only using like 5 feet. You see how srt4s come with rubber hose and they use blow off valve on the stock hose. That's kinds what I mean
VICTORIA RACING
fieromx3
Post by fieromx3 »
rubber hose for intercooler piping is dumb.. use metal piping in the reinforced silicone couplers.. the dsm's use rubber hose for intercooler stock but its gay lol
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
blackops032
BANNED Member
Post by blackops032 »
use steel or aluminum. its safer and you dont worry about blow outs then
Return to “Forced Induction”
